displaying posts 276 to 300 of 1309
Pages (53): first .. 11 [12] 13 .. last
Author Subject: Daveyboy's Rallye Race car
Post #276
Bad news is that the car makes 179.0 bhp [EDIT] (At the flyweel) 152 ft/lbs of torque and I am more than a little dissapointed to say the least. All credit to the guys at Track and Road, they know their stuff, it would appear that the car hasnt had uprated cams and I have had my expectations built up based upon an inflated power figure attained previously on another firms rollers.
So it would appear that with a decat, std. cams and a set of 45mm bodies 179 bhp is not a bad figure, at least I know there is more to come from fitting cams etc. in the future.
So now I'll be on the lookout for a set of PT82's some vernier pulleys, and a few other engine internals, watch this space...
Posted 3rd Jun 2009 at 13:31
chris with a pug
Post #277
Has Liam/chris still got that set for sale?
Posted 3rd Jun 2009 at 03:49
Post #278
Possibly mate, but spending is temporarily on hold, kinda wishing I'd gone low boost S/C instead of bodies now...Sad
Posted 3rd Jun 2009 at 03:51
Post #279
still.. the noise...
Posted 3rd Jun 2009 at 04:24
Post #280
you're not happy with 179 ATW ? that's pretty much over 200 bhp @ Flywheel.
guess you don't know what spec the cams and pistons are then?
Posted 3rd Jun 2009 at 05:03
chris with a pug
Post #281
I thnk he ment 179 at the fly wheel, thats what he said when he text me earlier,
Posted 3rd Jun 2009 at 05:25
Post #282
Yeah, my mistake, 179.0 at the fly Sad
Posted 3rd Jun 2009 at 05:43
Post #283
Ouch Sad
Post #284
Noise alone is not worth 1,200 beer tokens...LOL
Posted 3rd Jun 2009 at 05:44
Post #285
phillipm wrote:
Ouch Sad
yep Sad
Posted 3rd Jun 2009 at 05:49
Post #286
Much gain in the midrange or the same story there?
Posted 3rd Jun 2009 at 05:59
Post #287
I'll take some pictures of the dyno sheets from previous runs and todays, and post them up tomorrow, I have a horrible feeling I have had no real gain over the standard intake plenum Shock
Posted 3rd Jun 2009 at 06:03
Post #288
179 atf sounds like stock cams...
in which case, its time for pistons and cams, that'll be another k on parts Doh
Posted 3rd Jun 2009 at 14:37
Post #289
Marvelous Dry
Posted 3rd Jun 2009 at 16:25
willygti
Post #290
hard luck mate - but at the end of the day you have an amazingly minty car with tb's which is my ultimate goal for mine so you're already the envy of me. with cams you'll be sorted plus you'll be shooting flames like no tommorrow. Devil
Team Ducati 748
2003 Subaru Impreza STi
Posted 4th Jun 2009 at 15:13
fletch
Track Head
Post #291
PT82s foul on the oil spray bars I believe, so you'll need to come up with a solution if using those cams.
Posted 4th Jun 2009 at 15:23
Post #292
either mod them to clear or do away with them and block the holes Wink
or choose ones with a slightly smaller base circle...
Posted 4th Jun 2009 at 17:14
millic333
Post #293
179 without cams is pretty darn good!
Should see over 200 with decent cams. Looking forward to seeing you part with another k so i can see how the progress goes! Whistle
sharland wrote:
Your life is like an action movie. And I want in.
CARL.
Posted 4th Jun 2009 at 17:50
Post #294
I really would'nt mind that it's not making good power, it's just it drives just like it did when I had that awful modified plenum I made in it. Gutless down low then you get it all at the top end, but it's too little too late.
Getting off the line in a hurry is hard work with so little torque (having the lightened flywheel does me no favours there either) and a 10 bhp gain with what feels like quite a big drop in midrange power and torque has left me with a rather unsatisfying drive.
Here are the Dyno printouts, take the figure fro Regal with a pinch of salt because I can se no way it was achieving that figure having seen what it makes now.
Before:
After:
Posted 5th Jun 2009 at 03:00
rich_w
Post #295
It may not be as bad as you think Jim No
Look at the wheel HP figures.
Regal is 139 - this is regarded as pretty much spot on for a standard '6.
The Track 'N' Road graph shows 164 @ the wheels.
So you've gained 25 BHP at the wheels - sounds alright to me? Unsure
There maybe many reasons for the vast differences in engine BHP / theoretical transmission losses.
It's often down to the dyno and the software that's used with it.
Some dyno's like Bosch will measure coastdown losses, and add this to the measured dyno HP. This is the better way to calcualte theoretical transmission losses.
Some like Dyno Dynamics add on a flat-rate percentage, normally 15-20%. Which is obviously a load of rubbish.
If you ever manage to speak to Wayne Schofield he will be able to tell you much more about it:
chipwizard wrote:
Things that affect wheel power v flywheel power readings...
Tranmission drag (oil type, temp, clearances, wear etc...) Driveshaft drag (you see small changes to this with different ride hights and thus, shaft angles)
Mostly... tyres. Make, type, width, compound, pressure, temperature, toe, camber (the roller contact patch is not at the bottom of the tyre so camber causes scrub of course) etc.
Roller diameter (smaller rollers cause greater tyre deflection and thus, greater losses) and roller separation as the car sits deeper into the rollers if they are further apart and this causes greater losses (with improved grip)
Contact Details:
07732 822546
Posted 5th Jun 2009 at 03:48
Post #296
Thanks Rich, I suppose it's not too bad when you look at it like that. I can't help but wonder If I have gone for the wrong length trumpets, I'll measure the inlet tract on the plenum chamber tomorrow and compare it to the TB setup I have now.
If I have replicated the length I had with my modified inlet (which performed very poorly) then I may well have transferred the problem to the TB setup I have now.
Posted 5th Jun 2009 at 04:06
rich_w
Post #297
The trumpet length won't make a huge amount of difference to the overall power - i.e. the area under the curve.
It will change the delivery though; shorter trumpets with make more power, higher up the rev range, although you will lose some low end power/torque.
Increasing the length of the trumpets has the opposite effect - you will bring peak power and torque lower down the rev range.
Smile
Contact Details:
07732 822546
Posted 5th Jun 2009 at 04:15
Post #298
Best way to see if it's any good is to find out if I can roast any standard 6's at Rockingham next weekend! Ninja
Posted 5th Jun 2009 at 04:24
Post #299
6's drop off from not having enough flow from the cam profile higher up the range anyway, so longer trumpets might not be a bad compromise, the extra air mass might work fairly well to negate some of the effects of the longer trumpets up top, and knocking a little of that blip from the harmonics at 5500rpm further down should fill the midrange in a bit.
You can get spacers cheaply for the trumpets on jenveys, can't remember who does them though, to alter the intake length in varied amounts for trail & error work.
You really should have the inlet cam timing matched to the intake length either way though. Dunno
How long is your inlet tract length at the minute?
More importantly, what did the arse dyno say before it was influenced by the rollers?
Posted 5th Jun 2009 at 05:11
Post #300
I'll have a measure of the inlet length today, the old bum dyno was telling me that the car felt 'flat' before the map/dyno session, but I put that down to the fact that it was running on the basemap.
After the map though I have to say apart from the engine running smoother I could'nt feel much of a differnce in acceleration.
Posted 5th Jun 2009 at 13:39
