On the same RR my std road GTI6 showed 163.8 bhp atf and 139 bhp atw with 141 lbft. The same car illedgedly had 185bhp atf and 147 bhp atw at another RR!
| Author | Subject: Daveyboy's Rallye Race car |
ash
Six Addict Location: Chelmsford Registered: 25 Mar 2003 Posts: 7,520 Status: Offline |
Post #301
Good to see you went to the best RR with the best operators and accurate readings.On the same RR my std road GTI6 showed 163.8 bhp atf and 139 bhp atw with 141 lbft. The same car illedgedly had 185bhp atf and 147 bhp atw at another RR! |
willygti
Seasoned Pro Location: Exeter Registered: 08 Oct 2007 Posts: 5,024 Status: Offline |
Post #302
sell it... to me? ________________________________________ Team Ducati 7482003 Subaru Impreza STi |
Post #303
willygti wrote: sell it... to me? Make me an offer ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
matty_rallye
Senior User Location: Devizes Registered: 28 Oct 2005 Posts: 966 Status: Offline |
Post #304
I would personally look at the whp outcome and if it was mine id be pleased with 164 bhp atw with whats been done. It is quite and improvement over the standard whp! ________________________________________ 2.1 16v 306 Rallye. |
matty_rallye
Post #305
Just read the thread through from the start, cracking job!!________________________________________ 2.1 16v 306 Rallye. |
Post #306
ash wrote: Good to see you went to the best RR with the best operators and accurate readings. On the same RR my std road GTI6 showed 163.8 bhp atf and 139 bhp atw with 141 lbft. The same car illedgedly had 185bhp atf and 147 bhp atw at another RR! Track n Road were reccommended to me personaly by a friend who had some really good help from them. I was amazed to see how committed they were to accuracy, there were two meters checking the AFR, they calibrated their lambda before the start of each session (which I burned myself fitting! ) they used an airconditioning system to provide cold, rather than just moving air to the engine. I was very impressed by their level of competence and they were very thorough. (Especially in the time they had available, a full map would be ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Post #307
matty_rallye wrote: Just read the thread through from the start, cracking job!! Thanks mate, after getting plenty of feedback from other members on here I'm a lot happier about what I got at the end of the day. My dissappointment was down to the previous RR figure giving me a false impression of what to expect once the TBs went on. That and the fact that the power delivery is'nt what I'm used to seemed to make it slower, but now I'm getting used to it I'm pretty chuffed tbh. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
ash
Post #308
daveyboy wrote: The more I drive it the more used to it I'm getting, it's just a little more hard work keeping it in the sweet spot on the road as I normally change up at 5.5k unless I'm feeling really keen! Now you have to run it all the way to 6.5k if you don't want it to drop out of the power band at the next gearchange. And that makes a lot of noise and attracts unwanted attention 5.5k / 6.5k max! You should be using 7.5k! Unwanted attention |
Post #309
ash wrote: daveyboy wrote: The more I drive it the more used to it I'm getting, it's just a little more hard work keeping it in the sweet spot on the road as I normally change up at 5.5k unless I'm feeling really keen! Now you have to run it all the way to 6.5k if you don't want it to drop out of the power band at the next gearchange. And that makes a lot of noise and attracts unwanted attention 5.5k / 6.5k max! You should be using 7.5k! Unwanted attention ![]() Torque and power are all on the way back down after that point on a std lump. After new rods etc. though... ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Post #310
daveyboy wrote: The more I drive it the more used to it I'm getting, it's just a little more hard work keeping it in the sweet spot on the road as I normally change up at 5.5k unless I'm feeling really keen! Now you have to run it all the way to 6.5k if you don't want it to drop out of the power band at the next gearchange. And that makes a lot of noise and attracts unwanted attention not really, as it delivers more power and more torque than it used to, so you should rev it less to make the same progress, just doesn't feel like it ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #311
daveyboy wrote: Torque and power are all on the way back down after that point on a std lump. After new rods etc. though... Yeah, but it stops you dropping into an area of ever less power when you change gear, redline it everywhere ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
miles
Post #312
Intresting this, A mate of mine with a 205 with the old MI in it with 45 Carb;s (Yuk), Inlet cam and exhaust manifold made 170 bhp at Aldon's then on another RR is made 210bhp,Just ignore the figures and how it drives is the most important thing They should make around 190 in std form, ________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
Post #313
phillipm wrote: daveyboy wrote: Torque and power are all on the way back down after that point on a std lump. After new rods etc. though... Yeah, but it stops you dropping into an area of ever less power when you change gear, redline it everywhere ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
chris with a pug
Seasoned Pro Location: Southampton Registered: 16 Feb 2003 Posts: 5,366 Status: Offline |
Post #314
so stop driving it like the big girl you r and rag the bollox off of ot |
Post #315
chris with a pug wrote: so stop driving it like the big girl you r and rag the bollox off of ot Oh I intend to mate, we'll see how you like me ragging it round Rockingham with you screaming like a girl in the passenger seat! ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
spiky
Seasoned Pro Location: Cardiff Registered: 13 Oct 2006 Posts: 2,310 Status: Offline |
Post #316
not so bad after all ![]() need to get mine on a rollers to see what it is now making now, before the mapping session, thenm again afterwards ________________________________________ Do you need a 205 > 306 gti6 plug and go engine loom? PM METORQUES for all your braided fuel line needs MY YouTube Videos' SUPERCHARGED 205 GTI6.... are you Fooking nuts!.... ummmm YIP ![]() 268+BHP and 860kg = FUN |
Post #317
spiky wrote: not so bad after all ![]() need to get mine on a rollers to see what it is now making now, before the mapping session, thenm again afterwards Yeah, I just need to get out and drive it now ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Post #318
Got these today Nothing like underbonnet bling to put a smile on yer face Need a set of PT82s to go with em though... ![]() ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
spiky
Post #319
py82's? you got pocketed pistons?________________________________________ Do you need a 205 > 306 gti6 plug and go engine loom? PM METORQUES for all your braided fuel line needs MY YouTube Videos' SUPERCHARGED 205 GTI6.... are you Fooking nuts!.... ummmm YIP ![]() 268+BHP and 860kg = FUN |
Post #320
Not yet, I'm collecting parts with a view to rebuilding the engine with forged internals as soon as I can afford it. These are the first step on the way. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
spiky
Post #321
i really should get a set too,the mrs isn't buying the "cheap"track car anymore ________________________________________ Do you need a 205 > 306 gti6 plug and go engine loom? PM METORQUES for all your braided fuel line needs MY YouTube Videos' SUPERCHARGED 205 GTI6.... are you Fooking nuts!.... ummmm YIP ![]() 268+BHP and 860kg = FUN |
chris with a pug
Post #322
Nice set of paper weights |
Post #323
spiky wrote: i really should get a set too, the mrs isn't buying the "cheap"track car anymore Haha, well done for getting away with it so far ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
brett-black-rallye
Senior User Location: felixstowe Registered: 28 Aug 2007 Posts: 573 Status: Offline |
Post #324
i could sell ya some bp285h cams |
Post #325
Just for fun next week I have another fault to fix. I'll make a list:Reversing lights (Inoperative) Speedo (Inoperative) Heater matrix (leaking into the drivers side footwell) ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
