displaying posts 1 to 25 of 87
Pages (4): [1] 2 3 .. last
Author Subject: Ultimate Road/Track Rear Beam
rallyestyle
Ok so i have recently been thinking about what sort of suspension/handling setup i am going to end up with on the Rallye and have this in my head:
Front:
- Bilstein B8's with Eibach Springs. Lowers by about 35mm.
- Rich W's Roller bearing wishbones
- Maybe some of Phils fancy droplinks
Rear:
- Standard Pug dampers
- Ash's hybrid Arb
- Xsara 21mm Torsion Bars
- Rebuild of beam at same time with standard pug stuff.
- Solid rear beam mounts
I want the car to be for the road but very capable as soon as it steps on track while ofcourse not costing the earth to complete and maintain.
Does anyone think there is anything i have missed out/can improve on before i kick things into motion?
Cheers Smile
Cheers,
Just Drive It
Posted 19th Feb 2010 at 17:15
fletch
Track Head
Solid rear beam mounts possibly, depends if you like the rear-steer.
Posted 19th Feb 2010 at 17:12
rallyestyle
Ah yes, good thought Yes I have grown to like the rear-steer but something tells me i will enjoy it more without it Yes I shall update...
Just Drive It
clen666
Lightweight wheels? Not exactly suspension but they will help it perform better
Team 'unintentional rat look'
Posted 19th Feb 2010 at 17:31
fletch
Track Head
Great idea!
It just so happens I have some here for sale Whistle
Posted 19th Feb 2010 at 17:32
If you can build in some more negative camber front and rear you will find more grip when cornering. Wink
Posted 19th Feb 2010 at 17:36
fletch
Track Head
Bit overboard for the road though.
Posted 19th Feb 2010 at 17:39
+1
Better braking, steering and damping all in package Yes
Posted 19th Feb 2010 at 17:42
Depends how much you have, 3 degees is a little much as you will get premature wear on the shoulders of your tires. However if you can pick up some adjustable top mounts you can mix and match as much as you want. Then for the rear if you can get an extra degree of camber using Bridgecraft Engineerings trailing arms while you refurb your beam (Ideal time) then you will be laughing.
Posted 19th Feb 2010 at 18:38
rallyestyle
Good thoughts guys, am liking them Yes
My wheels are already taken care of although i could possible do with a spare set, have to be 16" or bigger though, fletch?
Brakes are taken care of with my AP Racing setup plus i have a set of carbone lorraine pads to slide into them for track work Ninja
Im up for some adjustable top mounts as i dont think they cost the earth Yes May be a phase 2 addition though, however i cant rebuild the beam and have neg camber on just the back Doh
Perfect responses, all top stuff without going insane Smile
Just Drive It
Posted 19th Feb 2010 at 18:46
soton_s16
Sorry for the slightly off topic, but how much are those trailing arms? I tried a google search, but couldn't really find much.
For all your Peugeot needs PugRacing.com
Gti S16 199bhp 164 ft lbs torques!
Posted 19th Feb 2010 at 18:56
rich_w
As already mentioned, I would possibly go for some solid rear beam mounts and perhaps the Bridgecraft Engineering negative camber stub-axle mod.
I would also get some better dampers - I don't think the OEM ones will be up to the job if you're increasing the spring rate with the thicker TB's etc.
I'm starting to build a new rear beam for mine as it's completely goosed.
Specification is:
- Bridgecraft Engineering modified trailing arms / stub axles - 3 degrees of negative camber
- 21mm torsion bars
- Ash Hargreaves hybrid ARB
- KW V2 rear dampers
- Will rebuild with standard bearings / seals etc
Smile
Contact Details:
07732 822546
Posted 19th Feb 2010 at 18:58
rallyestyle
Specification is:
- 21mm torsion bars
Smile
Cheers Rich, sounds like you are thinking along the same lines as me although my rear beam is not dead already thankfully Smile I will look into the rear dampers, thats a good point Yes
Just Drive It
Posted 19th Feb 2010 at 19:16
smegal
Let me know how you get on. My beam will be the next thing I spend money on.
Ex SC-6
Now in a Megane R26
Posted 19th Feb 2010 at 19:21
mabgti
NV motors
how much is the Bridgecraft kit? MR CRF450 is it?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 19th Feb 2010 at 22:11
stu
If it's Phills droplinks you want, then take a look >>here<<. Only need one more person for the Group Buy. Thumbs up
[/shameless plug]
Posted 19th Feb 2010 at 23:27
chris with a pug
+1
Posted 19th Feb 2010 at 23:34
lotek
Posted 19th Feb 2010 at 23:58
mxcrazy
When i asked last year some point it was
Posted 20th Feb 2010 at 00:07
chris with a pug
Is that on an exchange basis?
Posted 20th Feb 2010 at 00:24
darkgti6
fletch wrote:
Great idea!
What wheels for sale fletch?
Team Peugeot Sport 308 Gti�
Posted 20th Feb 2010 at 00:27
Solid beam mounts with ash's arb makes a hell of a difference also with lighter wider wheels. Roller bearing with xsara trailing arms would be nice also thats next on my list Ninja
Posted 20th Feb 2010 at 00:51
vts_tibi
seems like I did really good with suspension mods yet as my present suspension od list is nearly the same
need a hybrid ARB from Ash, and AST topmounts
and perhaps some solid rear beam mounts Ninja
VTS
best 60' : 2.272
Team Trackday™
Posted 20th Feb 2010 at 01:19
anderoo
Why xsara trailing arms? I thought the 6 ones were regarded as better?
Pics of my 6
My 6 on Google Video thanks to coxy306Xsi
Posted 20th Feb 2010 at 01:37
just a tad more camber if i member right mate
Posted 20th Feb 2010 at 01:48
